Getting Started with Scroll pHAT HD
Learn how to install and get started with your Scroll pHAT HD
This tutorial will show you how to install the Scroll pHAT HD Python library, and then walk through its functionality - how to light pixels, display text, and so on - finishing with an example of how to make a stripey animation with trigonometric functions.
These instructions should also help you get to grips with the updated Scroll HAT Mini - for examples of how to use the buttons on Scroll HAT Mini check out the Python library.
If you haven't already soldered the header to your Scroll pHAT HD, then you can follow our guide to soldering pHATs here.
As with most of our boards, we've created a really quick and easy one-line-installer to get your Scroll pHAT HD set up. We'd suggest that you use this method to install the Scroll pHAT HD Python library.
curl https://get.pimoroni.com/scrollphathd | bash
Using the software
Lighting individual pixels
We'll start by looking at how to light up individual pixels. The pixels on
Scroll pHAT HD are addressed by x/y coordinates, so to light the second pixel in
the first row, for example, this pixel would be 0, 1. Remember that in Python
we number things from 0, hence the first pixel is 0, the second is 1, and so
on.
Before we start anything, we have to type the following to import the
scrollphathd library:
import scrollphathd as sphd
The import x as y just means that we don't have to type the rather long-winded
scrollphathd each time we want to call a function, just sphd.
As well as the x/y coordinate of the pixel, we also have to pass in a brightness
value. Brightness is a floating point (decimal) number between 0.0 and 1.0.
We'll use the set_pixel function to light the second pixel in the first row at
50% brightness. Type the following:
sphd.set_pixel(0, 1, 0.5)
sphd.show()
You'll notice that as well as using the set_pixel() function to tell the library
which pixel to light, we have to call show() to update Scroll pHAT HD and
actually light the pixel.
To clear any set pixels, there's a clear() function. Just like the
set_pixel() function, you have to also call show() to update the display.
Type the following to clear the pixel you just set:
sphd.clear()
sphd.show()
Lighting whole rows or columns
Getting a whole row or column to light is basically the same as lighting an
individual pixel, except that we have to repeat it once for every pixel in that
row or column. We can do that using a for loop. We'll light all of the pixels
in the second column from the left now (remember that it's numbered 1) at
25% brightness this time.
Type the following:
for y in range(7):
sphd.set_pixel(1, y, 0.25)
sphd.show()
We can take this a little further and use another for loop to loop through
all of the columns and light each one in turn. We'll introduce a new module
here - the time module - and use it to introduce a small delay between
lighting each column.
Before we begin, we'll clear that column that we just set:
sphd.clear()
sphd.show()
We'll use one for loop - for x in range(17) - to loop through all of the
columns, and a second for loop - for x in range(7) - as we did before to
loop through all of the pixels in each column.
for x in range(17):
sphd.clear()
for y in range(7):
sphd.set_pixel(x, y, 0.25)
sphd.show()
time.sleep(1/17.0)
Your Scroll pHAT HD should just have scanned across from left to right and lit all of the columns in turn.
Notice that we called clear() before each iteration of the
for x in range(17) loop, so that any columns lit already would be cleared each
time. If we hadn't done this, then the columns would all have filled up one at a
time.
Also notice that we called show() outside of the for y in range(7) loop, so
that all of the pixels in each column were lit at the same time.
To keep that going indefinitely you could wrap the whole thing in a while True
loop, as follows:
for x in range(17):
sphd.clear()
for y in range(7):
sphd.show()
time.sleep(1/17.0)
Press control and c to break out of that loop.
Displaying text
As well as lighting individual pixels or groups of pixels, the Scroll pHAT HD
library provides a handy way to scroll text across its display. You simply use
the write_string() function to write a string to the buffer and then
repeatedly call show() and scroll(1) functions to show the text and then tick
it along by one position.
We'll write and scroll the string "Shiver me timbers!":
sphd.write_string('Shiver me timbers!')
sphd.show()
sphd.scroll(1)
time.sleep(0.05)
If you have a shorter string, for instance a temperature string like 21C, and
you don't want to scroll and just display it statically, then you can use the
write_string() and show() functions without calling scroll().
Note that the default orientation for Scroll pHAT HD is upside-down if
you're using it in a Scroll Bot. To flip it, simply add
scrollphathd.rotate(180) towards the top of your code, just below the import
lines.
Using trigonometric functions to create a simple animation
We'll take it a little further now and use a couple of simple trigonometric functions to create a dazzling stripey effect. Here's the code, and we'll break down how it works bit-by-bit after:
import math
t = time.time() * 10
for x in range(17):
for y in range(7):
b = math.sin(x + y + t) + math.cos(x + y + t)
b = (b + 2) / 4
sphd.set_pixel(x, y, b)
sphd.show()
Let's look at what all that does.
We use the time.time() to get a time value to which we'll apply our trig.
functions. We could simply iterate a number and use that, but the drawback of
doing it that way is that we don't know exactly how long each iteration of the
loop will take and our animation might not be as smooth as it could be. The
time is multiplied by 10, which has the effect of speeding the animation up a
fair bit.
Next, we use two for loops, as we did before, to loop through all of the rows
and columns of pixels, and set each one, passing it a brightness value b
between 0.0 and 1.0. This is the important bit!
b = math.sin(x + y + t) + math.cos(x + y + t) applies a sine function to the
x pixel number + y pixel number + the time value t, and a cosine function
to the same numbers, and then adds the results together. Each of those functions
will return a result between -1 and +1, meaning that the sum of them will be a
number between -2 and +2. To get back to a number between 0.0 and 1.0 for the
brightness, we add 2 and divide by 4.
Outside of both of the for loops, we call show() to update all of the pixels
at once.
Try experimenting with different trig. functions to create different patterns. You should be able to create horizontal or vertical stripes, or even a funky plasma-style pattern.
Why not throw in a bit of IoT and use your Scroll pHAT HD to display the news headlines, the current weather, or track a particular hashtag on Twitter?
