Internet Radio on your Pirate Radio
In this guide, we'll be turning your Pirate Radio into a proper internet radio. We've even configured the buttons on the pHAT BEAT to skip between stations, control the volume, and trigger a safe shutdown. The VU meter will display the volume level of your music too!
We've wrapped the whole process up into a nifty one-line-installer that will install and configure everything for you, but we'll explain what it all does too in case you want to hack it yourself.
Because this software relies on the buttons on pHAT BEAT, it won't work (without some hacking) on pHAT DAC or Speaker pHAT, but it's perfect for the Pirate Radio Kit, or your own setup with pHAT BEAT.
We recommend using the very latest version of Raspbian Lite, and you'll need an internet connection to install VLC and such later (we'll explain how to do that in Raspbian Lite below). We'd recommend using either the NOOBS installer, which you can find here (ensure that you select Raspbian Lite when installing), or downloading Lite from here and then using the Etcher tool to burn the image to your SD card.
Currently, our internet radio installer is best supported by Lite, and may not work properly in the full version of Raspbian. Because Lite is... liter (sic) it should also run a bit more snappily than the full Raspbian.
Building the Pirate Radio Kit
If you're using the Pirate Radio Kit and haven't already built it, then follow our guide here to learn how to put it all together.
If you're just using pHAT BEAT, then make sure that you've soldered the 2x20 pin female header to it. Again, you can follow our guide to soldering pHATs. Connect a couple of speakers (or just one) to your pHAT BEAT's push fit speaker terminals.
Pop the pHAT BEAT onto your Pi's GPIO pins, if you haven't already.
Running the installer
Just to reiterate, you'll need an internet connection to run this installer. Pop the SD card into your Pi, make sure that the pHAT BEAT board is attached to your Pi (on its GPIO pins), and then plug in the power and boot up your Pi. Because you're using Stretch Lite, your Pi will boot straight to a terminal, but don't be scared!
You'll need to connect to Wi-Fi. To do this, you need to edit a file called
wpa_supplicant.conf
. Type the following:
sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
Use the arrow keys to move to the bottom of the file, and add the following, replacing the parts that say "YOURSSID" and "YOURPASSWORD" with the SSID and password for the Wi-Fi network to which you'd like to connect (make sure to keep the quotes; they're important).
country=GB
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="YOURSSID"
psk="YOURPASSWORD"
Once you've made those changes, press control
and x
, then y
, and then
enter
to save and close the file.
Now, type sudo reboot
and press enter
to reboot. Your Pi should now be
connected to Wi-Fi.
To run the installer, type the following:
curl https://get.pimoroni.com/vlcradio | bash
The installer will prompt you several times, and you should type y
for all of
these, and the installer should also ask if you'd like to reboot once the
installation is complete. If it doesn't, then restart by typing sudo reboot
again.
What the installer does
The installer does a few things.
The first is that it installs and configures the pHAT BEAT software, including the Python library, configuring the ALSA audio settings to route the audio out through the I2S DAC/amp on pHAT BEAT, and installing the ALSA plugin that drives the VU meter LEDs to display volume levels.
Second, it installs VLC, a versatile, cross-platform media playback and streaming program that also works via the command line. Our internet radio software uses VLC to stream and play back internet radio stations. It's pre-configured with 4 stations, including Slay Radio and Planet Rock, but you can add more, and we'll see how to do that later.
Last, it installs a couple of daemons to run the VLC process itself, and a script that enables the button controls. Daemons are programs that stay running in the background and will kick in when your system boots and restart if they crash for any reason.
Using your internet radio
Assuming the installation went successfully, your Pi should have rebooted and will now be streaming internet radio! What's that? You can't hear anything? To start playback, you'll need to press the play button on the pHAT BEAT. The buttons are labelled on the pHAT BEAT board itself and on the front of the Pirate Radio.
The functions of the buttons should all be fairly self-explanatory. The volume up and down buttons... turn the volume up and down. The forward and back buttons cycle through the stations, and the play/pause button will stop and start playback, although it won't pause it. The power button will trigger a safe shutdown of your Pi (note that it doesn't completely cut power, and to do that you'll need to switch off or unplug the power supply once the activity lights have gone out on your Pi).
Adding your own stations
The list of stations is in a file in /home/pi/.config/vlc
called
playlist.m3u
. You can edit it by typing
sudo nano /home/pi/.config/vlc/playlist.m3u
in a terminal, adding the URLs
for the stations, one per line, and then pressing control
and x
, then y
then enter
to save and exit. After rebooting (type sudo reboot
) the new
stations should be available.
There's also an easier way to do this. Shut down your Pi
(type sudo shutdown -h now
in the terminal) and remove the micro SD card. Pop
it into your desktop or laptop's SD card slot, and it should mount the boot
partition. You can now use your favourite text editor to add the URLs of the
internet radio stations, one per line, saving the file with the filename
playlist.m3u
. When you put the SD card back into your Pi, our software will
copy that file across to /home/pi/.config/vlc/playlist.m3u
and the new
stations that you added should be available.
You should be able to find URLs for streaming internet radio stations by Google-ing something like "internet radio stream URLs".
VLC actually includes a rudimentary web interface for controlling the stream
remotely. You should be able to access this by going to the URL
http://raspberrypi.local:8080
or http://192.168.0.2:8080
(where 192.168.0.2
is the IP address of your Pi) in your browser.
