Setting up pHAT DAC
This guide will explain how to get pHAT DAC up and running on your Raspberry Pi using the Raspbian operating system.
Before you start, you should make sure that Raspbian is up-to-date, either by following our guide or downloading and installing the latest version.
pHAT DAC provides a line-level output, which means you should connect it to some speakers or a stereo system ready to test your set up. Don't use headphones!
Note that this configuration will disable the default sound modules on your Pi, so that sound will only play through the DAC. We're looking into a better configuration to allow switching between the two, but for now this is the way to go.
Automated Set Up
First you should fire up Terminal on your Raspberry Pi. If you boot up to it, great, you're set, if you boot to desktop you can find it in the Raspberry Pi menu under Accessories.
The easiest way to get going with your shiny new pHAT DAC is to use our one-line installer, like so:
curl https://get.pimoroni.com/phatdac | bash
This script will set everything up for you whether you are running Raspbian Wheezy or Jessie (including Jessie Lite). You will need to reboot your Pi after the script has completed.
Once that is done and your Pi has been rebooted you may, if you like, run the above script again and it will offer you to test your setup summarily. PLEASE set your speakers at a low volume first however, then progressively raise the levels if you can't hear any sound coming out the pHAT DAC!
Manual Set Up
If you are interested in what the script mentioned above is doing, keep reading, though for most users that isn't necessary, unless you can't hear any sound coming out of the pHAT DAC after running the automatic set up steps as laid out above.
Note that those instructions were initially written for Raspbian Wheezy and meant as a troubleshooting guide outlining the principle of exchanging the default bcm2835 chip for the pHAT DAC to pipe audio through. Additions were made to cover Raspbian Jessie however.
Step 1: All The Modules
In Terminal, type: sudo nano /etc/modprobe.d/raspi-blacklist.conf to open the module blacklist file. This file prevents certain modules from loading at startup. With the file open, comment out the lines corresponding to the modules we want to load by changing:
blacklist i2c-bcm2708
blacklist snd-soc-pcm512x
blacklist snd-soc-wm8804
To:
# blacklist i2c-bcm2708
# blacklist snd-soc-pcm512x
# blacklist snd-soc-wm8804
If some or all of those entry are not present, don't worry, you are trying to disable those modules anyhow!
Finally, close nano by pressing CTRL+C followed by y for yes, and finally enter to confirm. You'll need to remember how to do this in the next few steps, too.
Step 2: Be Gone, Default Sound
Still in Terminal, open the modules file by typing: sudo nano /etc/modules. This file, in contrast to the blacklist, lists modules which we do want to load. We're going to remove the default sound driver with a comment, so change the line:
snd_bcm2835
To:
# snd_bcm2835
To prevent it loading (this entry should exist, if not you are likely running Raspbian Jessie, which configures the audio chip differently - this will be handled by Step 4).
Step 3: Sound Config
Finally, create a new asound.conf by typing sudo nano /etc/asound.conf and entering the following:
pcm.!default  {
 type hw card 0
ctl.!default {
 type hw card 0
Step 4: Device Tree
The last step is to edit your config.txt, type sudo nano /boot/config.txt and add the line:
dtoverlay=hifiberry-dac
pHAT DAC uses the same hardware as HiFi Berry, so we're borrowing their device-tree overlay!
While you have that file open, check for the following entry, and if it exists, comment it out:
# dtparam=audio=on
Reboot
Finally, reboot your Raspberry Pi and with any luck your audio should now blast through your connected speakers.
